Sony vFET pt2 N channel help
Hi
Need som help.
My left channel stopped working, no smoke or burned parts.
It’s not drawing any power, I am getting unloade voltage between + and gnd, on the output stage.
Power supply is working properly, it’s a SLB power supply.
Andreas
Post pictures please.
What is the voltage across R1?
What is the voltage across Z1? Does the voltage change when P1 is adjusted?
What is the voltage between mosfet drain and ground? What happens to the voltage when adjust P1?
Over R1 bad side 1.7mV. On good side 1.3V
Over Z1 bad side 0V. On good side 7.7V. Turning the P1 on bad side, nothing happens. Good side it gets adjusted.
Voltage between mosfet drain and ground on bad side ≈ 0V, turning P1 nothing happens. Good side 11V and rising (Cold amp)
Andreas
Between VFET and ground bad side 41V (unloade)
Good side 35.8V
What is the voltage between each side of R7 to ground?
What is the voltage between each side of R8 to ground? Adjusting P1, does the voltage change?
Voltages should be present and adjusting P1 should result in changing voltage. If no voltages I would suspect bad solder joints on the board.
