Sony vFET Amplifier Part 2
Put...Put...Put
I just switched from 89dB speakers to 94dB speakers.
Using TeaBag VFET2 boards with Botte suggested changes
With CLC PSU using 25V transformer: .
If I put my ear very close to the speakers I hear a put.. put.. put. Frequency is about a beat per second. Same for both speakers. At listening position can't hear the put put put - just great sound
Repeated using 22V transformers - same thing
Switched to a different CLC PSU using 18V transformer - no put puts
Thoughts anyone???
Much appreciated and thanks
Bob
aha
now you tells more ....
with PSU voltage - to have putput , try (temporary) "shorting" R20 (schm from post #11)
but!! "shorting" means not dead short (offset issue ) but just AC shorting with , say, 470uF cap , neg pole to gnd
idea is isolating FE from OS
if putput is gone , FE is culprit
is putput ( I like that worrrrrrrd!) is still there , OS is culprit
then we can go further
then mark that amp as Tractor , and build another
:rofl:
ok , few things :
-that amp really needs 28V rails , no lower , or it will be starved; you can go withh lower rails , but not without excluding series regs .... and that's another amp ....... but you already know all that
- go methodically; parts are cheap while random work is not , meaning - not overly efficient ....... so - just replace all TL431 in channel , then try again , rebiasing da thing of course ; good thing - it'll already be in ballpark when you power it up
then report here
Finally made some headway. Had it on some test speakers and everything is good.
My VFETS were not the best matches so you will see the 0.1 ohm resistors on each drain. In the end a Vgs difference of 0.4 didn't make that much current difference.
Distortion came out about .03% at 1 watt, 8ohm
