Sony vFET Amplifier Part 2
Now I wonder if someone could mill some H R Giger artwork
It´s up to you make your own interpretation.
Can be about audio as well :
HIgh-FIdelity amp with SIT
= SIT-FI
Papa amplifiers are naturaly futuristic
You're welcome.
I bought two also. I didn't want to be greedy - wanted to share the opportunity to purchase from a known good dealer.
Thanks again Ben, unfortunately Acronman just sent me an email to say the they had miscounted and had only one left instead of the 2 that I had ordered. I have cancelled the order as one is of no use for an SE stereo amp. Just have to see if anything else turns up 🙁.
The design of the "last go around" VFET amp that I am working on will
use any VFET / SIT, one per channel, so if you have an opportunity to get
two of anything you can build a pair of channels with them.
We do have enough of the Sony parts to offer about 400 channels.
I was lucky getting 10 pcs 2SK180 from Japan. All tested good. I assume it should work in single end design, however, it would be nice having an option for higher rail voltage so to get more output power. Or just paralleling them...
