Joined 2009
Looks interesting, albeit a bit pricey
Hi-Res Music Player with 1TB HDD
Playback Codec : DSDIFF (DSD); DSF; MP3; WAV (LPCM); WMA; AAC; FLAC; ALAC; ATRAC (NON DRM); AIFF (LPCM)
Analog FIR filters
1TB hard drive for local music playback and storage (you can add additional external drives)
DSD re-mastering engine converts all signals to DSD signals
Built-in Wi-Fi for app control and music transfer
Dynamic Range : More than 105dB
Separate transformers for Digital and Analogue pus's
Master clock for DAC uses low phase noise 'liquid crystal oscillator'
Analog FIR filters
Given the overwhelming level of interest here and having lived with it for not even a week I can share a few impressions and my user experience thus far.
I should also mention that it was purchased with the full knowledge that I will eventually modify the crap out of it.. lol
I have not yet opened the box and won't until I am beyond a few hundred hours of use and am sure I am beyond the infant mortality part of the service life curve. Sony ES hardware has a 5yr warranty in the U.S. so I will probably wait at least six months to a year before voiding it..
Basically this is a linux based quiet computer in a pretty box with predominantly linear supplies, and a few DC to DC converters for the processor and other digital circuitry.
There are three power transformers, one small one that powers the standby circuitry, one large one for the digital circuitry and one for the analog.
The digital audio processing includes an FPGA and an AD Sharc series DSP, the converters are mono mode PCM1795A one dedicated per channel. I assume the the post I/V filtering is GIC based but won't know until I take it apart. Both balanced and unbalanced outputs are provided. The unit oddly inverts phase - I can live with this quirk as my pre-amp allows me to flip out phase at will - I find it rarely matters.
As I mentioned the HAP-Z1ES runs linux and works rather better with Windows networking tools on the source computer than it does with the HAP Transfer software which is an insidious form of slow torture to observe in operation even over ethernet.. lol (It took 15hrs to transfer 130GB over ethernet, sluggish to put it charitably) and I've found that dragging and dropping files directly into existing or newly created folders on the HAP using Windows networking is much, much faster (at least 3X) and works just fine, the player software then goes out and gets the required meta data and updates the database very quickly. Pruning files or rearranging files on the Z1ES requires you to use the computer. (Downloads and file maintenance maybe performed with a laptop or any other suitable windows or McIntosh. Linux with Samba installed I suspect will work fine too - I will report on that as of if or when I get around to it.)
The player interface is very simple and intuitive on the front panel, the interface installed on my android tablet works extremely well, provides many options for navigating through the database, and also provides access to audio relevant control menus.
It even manages to sound good, my redbook format material probably has not sounded better on any device, and it does a great job with flac, wav, aiff, and dsd files at various sample rates and bit depths. Both DSD64 and DSD128 are supported (dsf and dsdiff files).
The DSD remastering engine can be shut off from the front panel or toggled from a menu on the android app. Yes, I can hear some very subtle differences between upsampling to DSD and straight PCM playback and have concluded that so far I prefer the DSD remastering engine enabled.
It uses less than 10% of the power of the hardware it replaced, boots quickly, and is simple and fairly quirkless unless you do something to make it unhappy. (I have.. lol) Make sure when you add files to it that it has an internet connection or it will not be able to update the database, and find your new files.
The sound is a pretty significant step up from what I thought was a competent diy dac. I think the biggest surprise was listening to a very familiar recording the other day and realizing I was hearing backing vocals that had been completely obscured by the previous dac used in the old media server set up.
I'd say it is pretty slick and very well thought out, probably what an audio appliance should be. Put your files in it, press play and it does the rest.
Joined 2009
Really as extended storage space, I manage my back ups on separate drives that do not remain connected when not being updated so this does not represent a problem for me. It does mean a little extra work if you do not trust the source computer or source which could as well be an NAS - computer still required to manage file transfers to the HAP.
The computer that I use for ripping and downloading has a complete copy of the library, but I could also transfer the contents of the HAP drive to another drive using windows networking - the internal and external drives on the HAP just appear as drives on the network.
It is essentially a really large high res iPod in a certain sense and incorporates similar functionality except that it can update its database whenever it senses new files have been written to either the internal hard drive or an external drive. The big difference is that it is not locked into a proprietary format, it will play all of the most commonly used high res file formats, the few it doesn't support are not widely used outside of the open source community. (monkey's, ape, and ogg vorbis primarily)
Joined 2009
I have tried the vtuner, it seems to offer a fairly comprehensive selection of internet radio stations across the globe. (IIRC it also has a search function for stations not included in the internal database) The DSEE has a mild but audible effect on some of the really compressed streams which is an improvement. Overall the internet radio support is a nice extra that I will not use much, its omission would not have swayed me from the decision to buy one. I don't find the sound quality of compressed streams or files particularly enthralling on any device even with some clever processing. I find 256K/320K are tolerable, but few streams run this bit rate..
Overall I would say the HAP is quite a competent performer and is a rather significant improvement sonically over what it replaced.
Joined 2009
Good to know.
I'm feeling more tempted to buy one of these than any other piece of hi-fi for the past decade. I may be more inclined towards the HAP-S1 due to it's lower price point.
There's no real competition for the HAP. Did you, by any chance, audition the Pioneer N50 in comparison ?
I actually haven't heard or seen the Pioneer N50, it's a relatively different product using external storage, and doesn't support DSD which was a consideration for me.
I liked the HAP-Z1ES when I heard it at Son et Image in Montreal, this was a major consideration in my decision to purchase.
The relative simplicity and the generous internal storage and ability to play all of the high rez formats at a high level of performance cinched the deal for me.
I can't vouch for the HAP-S1 as it is an entirely different machine and afaik was not designed by the same group of people. It does not have the DSD remastering engine, and most of the other engineering features that appealed to me. (Power supply architecture, audio path implementation [dual dacs] etc..) I heard one briefly but did not feel it was in the same league, though not bad for its intended purpose.
I listened to this Sony at T.H.E. Show this past weekend, with Sennheiser 700s and DSD files. The whole experience was fantastic. How much was due to the Sony vs. the DSD files vs. the headphones? Can't say. But particularly listening to Alan Parsons' I, Robot, there was just detail I had never heard before, and more importantly the tracks just "breathed" more. Sounded more open, or more fluid, I don't quite know how to describe it.
There may be cheaper or "better" ways to do this, but if you get this Sony then you're kinda done, don't have to think about it too much.
I am frequently surprised by little details I have not heard before when playing music through mine.. Voices are particularly natural sounding in some recordings, and the processing and effects employed are obvious in others. I guess the greatest complement I can give it is it gets closer to good analog (I am a vinylphile at heart) than I have heard digital do in the past. Interestingly this is particularly true of files ripped from CDs many that I had come to consider tolerable are actually engaging in a way they were not previously.
It is really intuitive in use as well, just well thought out. It's quick and responsive during navigation and playback, great user experience.
Joined 2009
I can't vouch for the HAP-S1 ... I heard one briefly but did not feel it was in the same league, though not bad for its intended purpose.
If I get the chance over the coming weeks I'll try and audition both units. I would hope that the price difference is reflected in the sound quality, but I would be hoping to meet my needs with the less expensive unit - I suspect that this would not be the limiting factor in my system.
Did you compare the two units with external amplifiers, the cheaper unit has it's own amplifier and that could be a quality bottleneck. I'd want to take the analogue outputs to an external amplifier.
Anybody else heard these units yet ?
Joined 2009
I belong to a local diy tube audio club and despite a large number of members (a few sufficiently well healed to be able to afford one of these) I remain the only one who owns one. No one is beating a path to my door to hear it either which is fine with me. (but I am a bit... surprised)
The serious digital folk think it is too cheap to be any good, the serious analog folk think because it is digital it can't possibly sound good. I have gotten this argument or a variant of it from several people I have recommended it to.
My guess is that there will not be many here able, interested or willing to spring for one of these.
It still gets my recommendation, and the hype in the audio press based on living with it for a while is largely true. It is certainly the best digital I have yet heard admitting to fairly limited exposure. (Benchmark, Ayre, Cambridge Audio, Asus Xonar, my expensive diy PCM1794A based effort which it very easily outclasses)
Nothing at all exotic about this box, just well engineered and competently executed, just about what you would expect of a statement consumer product from a large engineering corporation like Sony. It is super easy to use which is one of its charms.
Joined 2009
KevinKR wrote: I should also mention that it was purchased with the full knowledge that I will eventually modify the crap out of it.. lol
Just wondering if you have gone down that path? I have had one of these for almost a year now, and although I would have thought the same about modding it at one time I have found I really have no need or desire to change it now. I don't find any fault in its sound that needs to be "improved".
I'm not terribly motivated either, it seems pretty good as is. I do think from time to time that there is a quartet of electrolytics I'd like to deal with at some point..
I'm wrestling with so many other system problems at this point that it has dropped off of my priority list.
My impression is a recent Weiss 202 dac (one version back) might better it by a small margin, but at a huge increase in cost...
- Digital Source
- Sony HAP-Z1ES Hi-Res source (new 2014) ?
