Something to lighten the mood
Okay Allen, you got us going. Here is one that many of you may have seen but if not, try your hand at it. If it's easy for you, hold off on answering other than to say 'Incorrect answer' to the others if that's the case. It's not that hard if your mind works that way.
I had a devil of a time the first go round.
Thank you.
Thank you.
If congruent means, laid as in a usual brick wall, then I found the answer.
