Soldano hot mod v2 on oscilloscope
Your schematic , I’m not sure for the pins ,,, I mod it , pls tell I’m right ,that’s make sense for me
yes yes you are correct... my fault sorry .. it's mine nomenclantute... so the schem is this..... i make it but without 470pf caps , beacuse i dont have now .. so i makes it and i test it and the sound have more gain but noise and buzzy.. i dont add grid resistor on the third triode.. i test it now ..
Οκ … I rebuild the filament wire to be sure that the noisy one does not pass through there… but for now this is the adapter
thank you . but remember its prototype .. . the second that make it work will it better....for the ground have a cable on the side of the box with a alligator clip to "bite" the amp chassis....I will try that the cables are not close to the fillaments cables....however, I see and see your design again and again and it is strange to me that the extra gain stage that I want to add is at the beginning and not in the middle of the design... you want to take a look and maybe some mistake has been made... because the truth it's that I've explained it a little strangely... I'm sending you the original design of the jcm800 and your schematic
Οκ then … thanx again .. I'll buy the capacitors and I'll let you know how it works, by the way, the small classic ceramic capacitors... don't they work? I say this because I have such, but I know that they have a low volt rating
sooooooooo. i make some change to solve the oscilation.. i change the 47k anode resistor with 100k. and i add on the grid of third gain stage 39k - 100k and 330k ... and nothing... so im thinking to change the anode of the valve 2 from pin 6 to pin 1 . to take the current from the 1st socket stage and BOOM.. its work!!!!!! no oscilations .. now i rebuild again. to see the results
yes .. after a lot test with resistors . fouund the right point for me.. (the plate resistor on second valve is 100k the 150k make the sound more deep fuzzy )
tomorrow i send here and demo sound with stock jcm800 and adapter on it... really thank you zintolo
