software for series crossover calculations
No: think first. That way you'll have a better understanding. I'll ask again: if you have a [passive crossover] circuit, where does the ground actually lead to? Doesn't matter if it's series or parallel. If you answer that, you'll have answered your own question.
I'm sure, but what good does spoon-feeding do? If you figure it for yourself (it's a simple one) you'll have a much better idea about how it works.
Think. Those little ground symbols you draw on a crossover circuit diagram. When you build the crossover -where do they go? Do they just disappear into the aether? Or do they, just possibly, connect to something?
Jeff Bagby produced a table of filter values that give good impedance some years back. But I can't locate it right now.
The Third order one was for 8 ohm drivers:
591258d1484013729-flat-impedance-flat-power-response-design-flat-impedance-series-filter-circuit-png
591257d1484013729-flat-impedance-flat-power-response-design-flat-impedance-series-filter-fr-png
This sort of speaker:
Flat Impedance and Flat Power response design.
The drivers are impedance corrected. Notice the 3:2:1 ratio of values. Can't remember if I time aligned the model. Bafflestep is what always messes these things up from the ideal. But looks good to me.
Software | Visaton
