Joined 2009
ska-forum links
Mike,
I think if you don't mind, please post the links of corresponding threads on ska-audio forum, here. It would make us easier to navigate in ska-audio forum.
Many Thanks,
-- Peter
Everything I've done should be on a thread that is accessible.
I can post some here, just not a lot of time lately.
Mike,
Many Thanks,
-- Peter
Start a new thread here.I think I'd rather do my own pcb in the end as I want to make a version with only single pair of output devices. Since this will be a deviation from Greg's design I'll take it to a new thread or to Greg's forum.
I would look at the IRFP140/9140 on about 35V rails. No need to use 200V parts and the lower Rds helps. Then the obsolete signal transistors can use something much easier too
Why a single output pair? Why not use the schematics as it is and make a board for two pairs of mosfets?I think I'd rather do my own pcb in the end as I want to make a version with only single pair of output devices.
Joined 2009
Because a) two pairs requires matching which I admit is only a small additional cost and hassle, but b) because today, there are new MOSFETs that weren't available to Greg originally which can handle the power with only one pair, c) some people say that a single pair sound better at low level details than multiple pairs
Joined 2009
Mike's thread: SKA sponsored Audio Forum - Rebuild
Why use a CCS as an emitter load for the driver pair - this limits the current swing in one direction ?
Ok, you convinced me.Because a) two pairs requires matching which I admit is only a small additional cost and hassle, but b) because today, there are new MOSFETs that weren't available to Greg originally which can handle the power with only one pair, c) some people say that a single pair sound better at low level details than multiple pairs
Will there be boards available?
Joined 2009
Let's see how things progress - if I design a board for myself that others want to use I will not keep it to myself.
Great! Thanks, Bigun!
I like to see how things work in Spice. I've loaded up the schematic, but it's not set up properly - a starting point for somebody if interested ?
Hi Bigun,
Thanks for posting the LTspice files. I've had hours of fun.
regards
Joined 2009
The Zener mod was replaced by the RCR mod.
In a couple of threads I came across photos showing the zener mods. It will be nice if someone can post details of the mods for constructors to make their own comparisons.
Is the RCR mod mentioned in the quote above, incorporated in the latest released schematic?
Does R27 need to be changed from 2R7 to 10R?
Thanks,
Fewer parts...fewer chances to go wrong!
Joined 2009
Thanks,
Look over on the TGM7 - GB150 build thread - the RCR mod is a split of the current source tail resistor and a capacitor from the junction of the two resistors to the rail.
The zener mod is very similar, uses a zener to regulate the voltage at the same resistors.
My guess - Greg doesn't plan to release all the tweaks and mods. I believe he has confidence that the clever chaps on this forum will figure out their own tweaks and mods.
- SKA GB150D now public domain...
