Tinitus - I have ordered slightly too large 'lytic caps for C6 and C7 it's an awkward fit. Apologies for this, I may get correct ones in the new year.
guess I could have made the same mistake myself 😛
hmm, cannot check yet
I suppose there is a delay on the board orders with parts kit
Excellent solder job except for R6 perhaps?
Well spotted Per. I re-flowed it after looking at the pics. I find a good camera close up is excellent for inspection.
Tinitus - I have ordered slightly too large 'lytic caps for C6 and C7 it's an awkward fit. Apologies for this, I may get correct ones in the new year. I would advise soldering C7 inside pin before R7 maybe.
Per's BOM specs says 8mm
and these are indeed 10mm
(specs on ordered cap says 8-10mm)
I hope it will still be possible
can I please ask to accurately measure distance between solder pads ends
would it be possible to 'bend it over', and solder one side first ?
ok, thanks Per
cap is 10mm
but base plate is 11mm
and 12mm at solder pins
but 35V 100uf is ok size for other projects
cap is 10mm
Yes, I had also the similar situation with the SMD resistors, would I buy 30 for €1,60 or 100 for €2,10. I went for the latter option, maybe with some other project in the future I don't need to order some values...
The cap shall be 8 mm diameter to fit. It's approx. 11 mm across the pads.
Hi Per,
Is it too late for this GB ?
Serge
Hello, I have received my dozen of yellow boards during my long absence. I still need to be away from home until about next month, so building those is still in the far future.
- Group Buys
- Sjöström Diamond Buffer group buy
