SIT-3
Hi WBS, that is what I plan to do in the future. I have some quantity of 2SK28s. We can parallel two 2SJ28s. :):)
I am not so knowledged but I think 2SJ28 + IRF240 will do the same work as 2SK82 + IRF9240. If not someone please correct me.
You may also consider the Laterals such as 2SK135 and 2SK1058, different harmonic flavour. As per usual, evaluate both speaker polarities.
SIT-3 it's visible on all FW products chart :)
SIT-3 kit by Nelson..
can be something similar to this? It is the DIY Sony VFet kit that I did not assemble yet. I found that they can be used as DEFiSIT with IRF9240 replacing 2SJ28. :D:D
I tried this front end to my DEFiSIT output stage, and I like the sound, which is different from Firstwatt SIT-3. Maybe the FET regulation circuit could give some advantage?
The bias circuit for 2SJ28 needs to be converted for IRF9240 that needs negative voltage. :)
