Simply the Best - LiveWave AMP
sure is correct
this lucky idea is use a good op-amp (fet inp)
like fully-differential one
takes current from supply
sound better of NAD YAMAHA and ROTEL
i have DENON 1500 series DAC...
this Australian TDA1543 NOS have "LiveWave"
like no other
Version "2" ---> Cap-Out
see this modification
short the capacitor of voltage balance in NFB
and add 6X 4700uF capacitors on OUT
this solution expand your sound like a tube amp
because don't force the zero point on output
similar of transformer push-pull
next upgrade Ver. 3
fully complementary bipolar input...
Conclusions:
the traditional method to adjust automatically the dc offset outgoing from solid state audio amplifiers
is completely wrong from the point of view of the dynamic behaviour and integrity of musical timbre
because it adds compression emphasis to signal depending on the area described by the same
viceversa, the method of Free Run Mode®
allows through a decoupling of balanced capacitors
a proper transfer of information
and returns a natural sounding.
Re: Conclusions:
What does that mean?
OCN - Output Capacitor Ness
put in the output two or more capacitors
in balanced configuration
to decopuling DC on loudspeakers
don't create emphasis
if you have a pair of bipolars
with the same gain (selected)
you can feel the difference
when connect ground to the central point:
nothing
viceversa
have a resistor + single capacitor on input (integrator)
sure force your offset on zero voltage
but need time to discharge this value
try to short and listen LiveWave
frequency response is sufficient
the difference
at a glance
is the architecture :
the output capacitors regenerating another
because in parallel on the load
in the serial configuration instead
(the negative input integrator):
the load is in series
then suffers a delay
therefore involves a deflection
you can feel difference just with a simple test
trusted me, is not a detail:whazzat:
