Can you name a reliable vendor of 12 transistors BF 245 or 2n5457, please ?
I have difficulties finding such vendor.
Thank you, very much.
This guy looks like having the right thing.
http://www.ebay.de/itm/5-St-5-pcs-B.../331333733369?pt=Bauteile&hash=item4d25078bf9
Dear Sir,
Thank you very much, your link seems be a good opportunity.
Now "I have l'embarras du choix", what should I buy please... BF245A, BF245B or BF245C, please....?
How could I check their correct functionality, please (schematic and values)?
It's necessary to use similar (close enough...how close) transistors on my PCBs?
Warm regards,
Ion Bebe
Warm regards,
Ion Bebe
Sweet
have you settled for 1 ohm?
roughly you would have about 100mv ripple in that setup
Going to about 15 ohms decreases the ripple to aprox. 16mv
Per
and
No i havent really settled to specific values, just using what i already had in hand. Salas if i increase the value of R to 15ohm , how would that affect the reg down the line?
Sorry for bringing an oldie back online. What tools do you prefer to use for calculate this?
What input values is needed - current, voltage - more? What wattage is needed for the R part of the CRC?
I prefer seeing such stuff live on the scope but Duncan's PSUD2 isn't a bad software tool for that either.
Ok thanks salas, the scope will be used - what wattage is needed for the center R? The PSUD2 seems to be from a tube perpective - easy to miss things or overly concentrate on things not needed for SS. But the scope will be used of course and what wattage are we talking about for 1000uF - R - 4700uf? This so the fuse holds and the R doesn't burn 🙂
I've both seen and used an excel spreadsheet maybe (wouldn't call it a program) where one atleast could see the ideal graphs. Maybe it was in the SS or chipamp sections...
Resistor nominal power equal or greater than 3*(VRdrop*current)
Well, the facts on the table so far is that in a CRC setup the VRdrop goes from zero to maximum and the current from maximum to zero in an ideal circuit unloaded and without losses (RC not taken in consideration as the circuit is unloaded as I don't have the load constant in my head). I will find the tool i need eventually and work backwards to find plausible loads and other values given the facts I found in this thread.
Which of Q2x, Q3x and Q5x gains most of being matched between channels?
I have 4 sk117 at about 3,55mA and and a pair at 3,34/3,44mA - does it matter or am I into cosmetics?
Yes, cosmetics...
Nothing to gain, very near already. Keep the latter to Q2x.
Hi.
What specs are R6x looking for? I noticed that I have several good 33R but only plain Royal ohm 1% , of which only God knows the tempcos of, 22R.
Its just a degeneration resistor doing steady current so don't bother much. Its there to reduce the Idss thus dissipation of Q2x bcs it runs under a large voltage (Vin-3Vf).
Another FSP born...
All set for cabling...
First light 😎...
First light 😎...
Yes, mm as I have a few good ones I thought of giving them the best amplification 😀. Sonus Blue Gold, Stanton 881S mk2 and AKG P8ES Supernova... And some others as the usual Shures and a Pickering.
I use the switch to select different capacitances for loading to manufacturers specs.
In business...
In business...
Amazing cart...
This is very nice!
This is very nice!
I noticed that I made an mistake... I tought of not solder the 1M C6 as I have 6.754k on C5... Still - there it is 🙁
Ok, dealt with. Minor impact though.
This is very nice!
Can't just drop that in here and not say anything about that gorgeous tonearm.
- Analogue Source
- Simplistic NJFET RIAA
