https://www.rush-on-line.co.uk/cap_index.php
they usually stock what I need. Awful slow service but great availability..
Thanks for the good link
I connected the shield of both R-Core Tx to chassis more body, lows, highs, it's incredible the big improvement.
That's the correct way. Electrostatic shield goes to IEC ground prong and from there with a short cable to chassis.
How do you like the 15.33nF
what caps are you using to make the 15.33 ?
15nF teflon aluminium foil + 330pF silver mica
thank you
I see both as recommended types for highest quality audio.15nF teflon aluminium foil + 330pF silver mica
The parallel combination may give a synergistic boost to the audio performance of the 15n33F capacitance.
I will try that combination also
FT-1 15,3nF is a real improvement over the previous SM, but I am having some trouble... After the mod, left channel has more hiss than right channel (There is a difference of 9pF between the FT-1) can this be the reason ?
No
hi
I am looking buy Elna Silmic II or Nichicon Muse (KZ) , Black Gate or other GOOD caps but anybody knows that this a store http://percyaudio.com/Catalog.pdf ?
Any news Ricardo?
- Analogue Source
- Simplistic NJFET RIAA
