Simplistic NJFET RIAA
trimmer VR for Rs
Then add the trimmer in parallel to the existing Rs, or in parallel to a slightly higher Rs.
eg.
Existing Rs = 30r
Proposed range of Rs +-10%
Select 36r for Rs and 1k for VR trimmer +110r fixed resistor.
Minimum trimmed Rs = 36//[0k+110r] = 27r1
Maximum trimmed Rs = 36//[1k+110r] = 34r9
Set Vr to 70r for nominal Rs = 36//[70r+110r] = 30r
Now, let's look at the sensitivity of Rs for the VR tolerance
At maximum trimmed Rs:- VR+2% gives 1020r and trimmed Rs becomes 34r89
A 0.05% increase in trimmed Rs for a +2% tolerance on the VR value.
If Rs ~+-20% is required for a gain adjustment range, then use 36r in parallel with 75r +VR= 2k
Joined 2006
With a 300Hz test tone I measured the following values:
Tone volume.........Right.....Left
+12dB.................0.58V.....0.71V
+14dB.................0.80V.....0.98V
+16dB.................0.96V.....1.22V
Left plays slightly lowder and so hisses more.
I will now use the trimmers on second stage.
