Simplistic mosFET HV Shunt Regs
What about modding to use the Jung bias multiplier?
C1 cap could be 1uF & R5 & R6 1Meg
I need some help,
accidentally shorted outputs to ground.
Power supply before the regulator works but the led on the regulator not working and no output power.
I was taking voltage readings on the pre amp and my meter prob slipped shorting to ground terminal.
Any body know where I should start on what component or components I may have killed.
Hi, sorry for bad luck. Anyway, in post #1 there's a link to a troubleshooting example/dialog few posts long. Read that to find clues. In short you first make sure there's still a working CCS section then you check the voltage making section semiconductors. Vbe, Vgs, are health indicators.
Reactions: rob211264
Thanks Salas,
At least I got to enjoy the pre amp for a few hours the night before.
Sounded great.
I had to do a last voltage check and thats, that.
I'll try to follow the test procedures and with any luck get it back to the way it was before,
Grealy appreciate your help.
Reactions: Salas
