Simplistic mosFET HV Shunt Regs
CCS working OK
Hi Salas,
What is the real BW of your control loop?Any measurements available? I just found your thread, did not read all 5500 replies. Sorry.
Do you think is a good idea to attempt to tasking your regulated PS to deliver 2Adc+/-200mAac into an 1MHz BW audio current amplifier with THS+N <1mA into 16Ohms at160Vdc? My amplifier project is a Class A Circlotron and for example asks the PS for supplying this current(!) waveform (constant voltage) at 100KHz:
The 100KHz is max fundamental frequency so the needed relevant harmonics will reach up to 1MHz. So, being part of circlotron's signal path, the PS is asked to correctly supply up to 0.7A/us during these transients.
At less than 5KHz operation I will ask the PS to deliver 2Abias +/-1Asignal (I saw in first pages how to modify your schematic for this, big thanks!), but 0.7A/us condition still remains.
Summing up, your regulated PS looks to me very feasible for a Class A circlotron. It offers a tradeoff: the weight&size for cooling vs weight&size of capacitor bank. A very good trade in my opinion. It is not quite simple to build it but it looks capable. With dedicated output capacitors I hope to reach a firm control of harmonics up to 1MHz. The Circlotron's load is of course inductive. I hope the capacitor bank will not interfere with BW of regulation. What do you think, does it fly?
Any help will be appreciated. Thanks!
Hi Salas,
great, not shabby at all! Finally something in the ball park.What detail of component or module you think is most critical for increasing this parameter?
What would be the max. expected value (PS still nice behaving) for current slewrate capability assuming 2Adc at 160V?
Thanks,
-3dB at 25kHz open loop and -16dB at 100kHz open loop (for SSHV2 simulated)
I have a #26 pre with dual SSHV2 I made point to point and working fine for years. Never did blow anything.
The transformer you have has to much voltage for 150 Vout. Still you are not telling us your voltage drop, and rectifier schematic (choke or capacitor input, rectifier etc) in order to help you.
Exactly 322V, I use 250V tx (LCLC) + input choke 10H 100mA + 200uF + choke 10H 100mA + 200uF.
I have other tx of 125V, will be better to use it?
Rectifier hybrid Graetz AZ1 + two UF4007 (Between power transformer and the AZ1 one 100 ohms resistor.
Now only one 125VAC, attached Vout pic.
