First C only. But yesterday you had no B+ bcs of a broken trace? So an electronic cloud was sitting like mist hitting cobalt on glass making it great electric blue to look at?
I'll bet I am right, although I like your explanation better. Its more poetic and soothing than my inablility to execute a design😀
Need help
Salas,
I found my 26 pre-amp sound wired suddenly and the voltage on both R/L channels fluctuate quite seriously. The raw supply is stable at 172v. The LEDs are all on and I can't check the voltage reading since they keep swinging. The trimmers are working and can tune the voltage to certainly level, but jump to the extreme all in a sudden.
Albert
Salas,
Albert
Salas,
Albert
Oh....sorry, forgot to tell, mind is an old version SSHV1. Please see attached. Thanks
Hi!
My be Mje 350 , it is hot, and 840 died, please change it!
Hi!
Changing both MJE350 & IRF840, and both channels???
check it, if MJE 350 hot, please change it and IRF840!
The 840 is only 30c. I have to check the 350.
I've both the 350 & 840 changed to new. Not working, still swinging.
Check BE and GS voltages to see if fets and bjts are working.
George,
Thanks and I have them checked after taking out from the board so to compare. The new and the took-out ones - 350/840 - measured the same. I don't have any chance to take number when it's on. The voltage keeps fluctuating. I have 2 boards for L/R. While I set close to 150v on one side, then the other side shifted to different extreme, either very low/ or very high voltage. One thing I don't understand is when one channel voltage drops to very low, the other board's voltage go very high, even higher then the supply voltage.
Before this happened, I had 172v from the main then split to two boards. I could easily adjust to 150v without problem.
Albert
[QUOTE=albertli;
What the value of R1?
33 R or 27R
down R1, set current CCS for all, you can get the V-out !
Not: Use current =80%, and IRF 840 = 20%.
33 R or 27R
if you want SSHV much better filter, you need to replace C2 = 1uF capacitor with larger value, such 4.7uF to 10uF/400V.
Quanghao
Quanghao
Salas,
Albert
Oscillation most probably. Did you tweak something at the receiving ends?
Salas,
I didn't touch it after it was up. It's my plan to add a telfon 0.047 to C2, but can't find it still.
Albert
What the value of R1? 56R for 40mA
33 R or 27R
Not: Use current =80%, and IRF 840 = 20%.[/QUOTE]
Is it a benefit to run it too hot. What I need is 5mA per 26. It was running perfectly, but suddenly turn into this. I checked temperature for all fets and 2 legs, no sign over overheat. I didn't check the 170 yet.
33 R or 27R
You say your leds flicker?
leds light up as usual. Trimmers working, but only the voltage won't stay.
- Power Supplies
- Simplistic mosFET HV Shunt Regs
