Simplistic MosFET HV Shunt Regs
Joined 2009
The schematic is correct, but look at your photo, it seems the 56K is connected to the LED at one end with the other end connected to the 220ohm
Thank you very much bigpandahk, I'm happy my CCS is going on perfectly well after 10 minutes, old tx & IRF9610 used.
Now what I have to do: connect the rest of quanghao pcb with old tx or try first with Bartolucci tx and after connect the rest quanghao pcb?
diyAudio Chief Moderator
Joined 2002
Aha, progress. Why not you continue to create full reg on that same board with same rectification and Tx as you are having success...
