Simplistic mosFET HV Shunt Regs
At least double saturation current spec for the choke than the CCS setting.
So for 36mA = 75mA? If can't get 75mA wich will be better 65mA or 100mA?
With such current (36mA) can supply B+ for two 6922 tubes or I need 30mA per tube so 60mA because I have only one HV reg?
If only have one HV reg how much current to supply B+ for one ECC83 & one 6922?
You probably know best... how much current do one ECC83 and one 6922 draw in your circuit? Maybe not that much in a preamp, so let's say 3 + 5mA = 8mA...
Now make that double (approximately 😉)
I still have set the shunt reg (one for two channels) in my C3G headphone amp at around 80mA... simply because I was too lazy to change R1 which was chosen for another amplifier. My tubes consume about 15mA each so that makes 30mA. I have good heatsinks so I don't mind the excess 50mA... and it sounds glorious.
When this one will be cased up I will build (yet) another SSHV and set it at about 65mA (and make it as compact as possible).
Yes, since you were asking about current setting.
But I also misread your first question 😉... I would go for the bigger choke.
(Btw, I just added one to the pre filter in my Aikido... (with Salas shunt)
Maybe you are finding this interseting also... chokes are not static devices it seems.
http://www.roehrentechnik.de/html/reihe_m65.html -->see data
Reinhoefer has very good reputation around here, this is were I got my chokes and opt's...
Sure... just look at the graphs.
finished adjustment for the dual 300-0-300V last night for Exstata, and it works nice on dummyloads.
The SS modules have a very high Resistance, for like 1 sec, until its "fully" powerd up. Is it likely, that it will blow anything in the shunt PS (that always needs a load)?
If the load does not consume current for a while, then almost the total available from the CCS part it is consumed in the output Mosfet of the reg itself. As long as its sink can support that for a minute, nothing bad will happen to the reg. If its really only a for a sec, no worries.
P.S. Let us know how it went.
Which Mosfet? Both?
The limit is the output loop's parts max (the BJT's and the shunt Mosfet's). The input must not rise beyond 200V VDS max as a difference not to kill the input CCS Mosfet also. Something specific must have happened. Give us more details about the set up. Maybe you got some Zener and its a PCB?
at start up the output is at 0Volts.
The input will rise very quickly to your PSU voltage.
The CCS FET acts as a CCS to charge up the zero volt side to 300V.
340Vdc * 0.07A = 23.8W at the start of charging. Tj is going to rise very quickly.
The temperature de-rated maximum dissipation might be exceeded for the first few hundred ms.
But the Voltage rating has also been exceeded until the output has risen to 140Vdc. By then the FET has blown, due to excessive Vds combined with excessive Tj.
You should really use a 400V device for a 340Vdc supply that could vary +-10%, i.e. 310 to 370Vdc.
The worst case dissipation for the CCS FET is to short circuit the output.
In this situation I would expect the CCS FET to survive even though it might be operating with Tj = 149degC
That's how I determine the heatsinking requirement for this survive during fault mode.
