Simple DSD modulator for DSC2
Yes 1kHz 0dBfs. Scope vertical calibration was set ok, see attached pic. What's the Vrms output?
So how is the LP filter behavior? Something appears to be wrong somewhere. Do you have another dac to run the same digital test signal through? Measure its output with the same scope? Can you send the DSD DAC a software converted DSD signal instead of using Simple DSD Converter? Does that look okay? IOW, start thinking of ways to cross check and isolate where the problem is.
Attached pics with all possibilities for settings, please let me know what are the best settings TIA
So, you think its the PC or the DAC? Maybe check all the DAC power supplies/regulators for correct voltages?
If you hook up the dac output to your preamp/amplifier does it play at a normal volume level and gain setting (this is just another check on the scope calibration)? You could also put the scope in DC mode and use it measure a nominal 1.5V battery? How close is it to what a DVM says? However, IIRC you did measure your filter output but didn't say what the input source was. Was that enough to double check scope vertical cal?
