It appears to me that you have already configured the NAS to automount, but let's check with this command -I can give you the manual commands which will automatically mount your NAS each time DietPi boots.
Code:
sudo nano /etc/fstab
Code:
//<IP-address-of-NAS>/<shared-directory-on-NAS>/ /mnt/dsmusic cifs user=<SMBuser>,pass=<SMBpassword>,cache=none,iocharset=utf8 0 0
If that line already exists, you can modify it to add improvements - "iocharset=utf8" allows the use of special characters - useful for the German language!
I think (?) that MPD will allow sub-directories within the main music directory, but we will soon see. If it fails, there's another method where you can create symlinks./mnt/dsmusic
the directory structure is made up of several subdirectories (artist's folder for each album).
OK, now it's time to configure MPD. Open the MPD configuration file in nano -
Code:
sudo nano /etc/mpd.conf
Code:
music_directory "/mnt/dsmusic"
Code:
bind_to_address “localhost”
Code:
bind_to_address “any”
So under "audio_output {" you want -
Code:
device "hw:1,0"
Code:
type "alsa"
Code:
mixer_type "none"
Reboot.
Try to connect with an MPD client app ... for this you will need to know the IP address of your Odroid C1. If you have not done so already, it may be worth running the DietPi configuration again to set a manual IP address.
The infamous systemd may not be present on the NAS (yet) but I would recommend to take a safe defensive approach and consider using the mount option "nofail" in non-critical fstab entries already. Systemd has very unfortunate default options - e.g. failing boot when a no-nofail or no-noauto entry in fstab fails to mount - really annoying when upgrading from a tolerant non-systemd version to a newer version which has adopted systemd (hello debian...). The same for the default indefinite timeout on network interfaces startup when the network cable is disconnected or when the remote DHCP server does not run... but that is a different story.
Oh, if nano is not available in DietPi, you can install it with this command -
Code:
sudo apt-get install nano
At some point I was struggled last night. Now, things going faster, I’ve used the time for a clean install.
Side note: once again, I had to flash mSDHC with balena etcher on my wife’s windows machine. Failed on my mac, other pre-packaged distributions work. 😕
So what, these are my results:
BTW, I‘m getting fun doing all this on my „old days“ ...and with a little DOS in mind. But is it all worth it while RuneAudio does the things out of the box? As a perfectionist I would say „yes“. 😉
- network directory set (fstab)
- terminal acceess granted
- edit mpd conf (nano works!)
- alsa config
- installed app „MaximumMPD“ on iPad & config
- —> access to music directory, built up library
- installed myMPD for testing purposes --> access to web gui but no connection to MPD
- no sound/playback
- only static samplerate (@384kHz) in amp display even if it‘s just connected (no playback) - RuneAudio does it dynamic starting at 44,1kHz
- do I have to set the amp‘s maximum bit-/samplerate in alsa?
- found „upscaling“ option in mpd.conf —> disabeling? (don‘t want it)
- sometimes i get input/output erros (sdcard?)
- any other settings in configs that I have overlooked?
Config handling is clear so I think it's easier to show my configs for details:
My changes/adjustments
mpd.conf
fstab
What else is to change?
Edit:
Aaaah...run
Result:
...althoug autostart is set
Edit #2
Could restart it manually
mpd.conf
Code:
music_directory [COLOR="red"]"/mnt/dsmusic"[/COLOR]
playlist_directory "/mnt/dietpi_userdata/Music"
db_file "/mnt/dietpi_userdata/.mpd_cache/db_file"
log_file "/var/log/mpd/mpd.log"
pid_file "/run/mpd/pid"
state_file "/mnt/dietpi_userdata/.mpd_cache/state"
sticker_file "/mnt/dietpi_userdata/.mpd_cache/sticker.sql"
#user "mpd" # Set via systemd unit to preserve supplementary group permissions i.e. "dietpi"$
bind_to_address "/run/mpd/socket"
bind_to_address [COLOR="red"]"any"[/COLOR]
log_level "default"
#gapless_mp3_playback "yes"
#save_absolute_paths_in_playlists "no"
metadata_to_use "artist,album,title,track,name,genre,date"
auto_update "yes"
#auto_update_depth "3"
#follow_outside_symlinks "yes"
#follow_inside_symlinks "yes"
zeroconf_enabled "yes"
zeroconf_name "DietPi MPD"
#password "password@read,add,control,admin"
#default_permissions "read,add,control,admin"
input {
plugin "curl"
#proxy "proxy.isp.com:8080"
#proxy_user "user"
#proxy_password "password"
connection_timeout "30"
max_connections "4"
#max_playlist_length "16384"
#max_command_list_size "2048"
#max_output_buffer_size "8192"
filesystem_charset "UTF-8"
# Audio Output / Processing
# Disabled to allow native DSD output
#replaygain "track"
#replaygain_preamp "8"
#volume_normalization "yes"
audio_buffer_size "2048"
#buffer_before_play "10%"
audio_output {
type "alsa"
name [COLOR="red"]"Audiolab m-one"[/COLOR]
device "hw:1,0"
format "44100:16:2"
mixer_type [COLOR="red"]"none"[/COLOR]
#mixer_control "PCM"
#mixer_index "0"
# Disable DSD DoP MPD 0.19
dop "no"
# Realtime audio conversion & upscaling
#audio_output_format "44100:16:2"
#samplerate_converter "soxr very high"
fstab
Code:
Please use "dietpi-drive_manager" to setup mounts
# NETWORK
[COLOR="Red"]//192.168.178.3/music /mnt/dsmusic cifs username=xxx,password=yyy,iocharset=utf8,uid=dietpi,gid=dietpi,file_mode=0770,dir_mode=0770,vers=3.1.1,_netdev,nofail,n$[/COLOR] <-- by drive manager/settings
# TMPFS
tmpfs /tmp tmpfs size=1024M,noatime,lazytime,nodev,nosuid,mode=1777
tmpfs /var/log tmpfs size=50M,noatime,lazytime,nodev,nosuid,mode=1777
# MISC: ecryptfs, vboxsf (VirtualBox shared folder), gluster, bind mounts
# SWAPFILE
/var/swap none swap sw 0 0
# PHYSICAL DRIVES
UUID=d524574c-c83a-48c3-9211-b8eed72ec103 / ext4 noatime,lazytime,rw 0 1
UUID=C3D7-565C /boot vfat noatime,lazytime,rw 0 2
Edit:
Aaaah...run
Code:
dietpi-services
Result:
Code:
┤ DietPi-Services ├──────────────────────────────┐
│ Please select an option or program: │
│ ●─ Single Service Options ─────────────● │
│ avahi-daemon : active | Affinity 0-3 │
│ [COLOR="Red"] mpd : failed | Affinity 0-3 [/COLOR] │
│ cron : active | Affinity 0-3 │
│ dropbear : active | Affinity 0-3 │
Edit #2
Mmm, that's not good. I seem to recall that for Win32 Disk Imager give a 100% reliable image-write, it was first necessary to format the microSD card with FAT32. Maybe this is also true for balenaEtcher?sometimes i get input/output errors
I have also read that image-writes can be faulty with certain USB adapters - maybe you could try a different adapter?
But I must say, I'm concerned about the filesystem integrity of your microSD card.
That's great. Your client app can connect to the MPD server, and successfully read its database. Good start.these are my results:
installed app "MaximumMPD" on iPad & config
--> access to music directory, built up library
That's bad, but not necessarily MPD's fault. DietPi's ALSA setup might be bad.no sound/playback
Some diagnosis is in order:
Do you have some mp3 files in your music library? Try to play an mp3 file with a command line player - madplay or mpg123
Code:
sudo madplay /mnt/dsmusic/<some-other-directory>/mymusicfile.mp3
Code:
sudo alsamixer
You seem to have hard-coded the audio output format. I'm sure your dac can handle more than 44khz 16bit music. Just comment that part out.
Yes, wealas is correct.
Of course ALSA can mess with the audio output, too - resample, software volume adjustment,
but this can be disabled with the following configuration in /etc/asound.conf
Code:
pcm.!default {
type hw
card 0
ctl.!default {
type hw
card 0
Regarding the failure of MPD to auto-start, it may be that there are two different startup methods conflicting with each other.
So I suggest you reverse my earlier auto-start method, by doing this -
then autostart mpd from dietpi-services.
Code:
sudo systemctl disable mpd
Briefly in between...
mSD is quite new, all past flash operations were successful. Only the DietPi-image failed. Took the same adapter on macOS and Windows, preparations in same order: deleted old volume(s), create a new one (FAT32) --> balena etcher --> flashing and verification successful.
In the meantime, I'll do my homework... 😉
I wonder if mpd is scanning your library and using up all the cpu resources. Maybe disable the mpd service and run
speaker-test -c2 -Dhw:1,0
That should put out pink noise one speaker at a time.
Perhaps dmesg output could put more light on the cause. Maybe insufficient USB power causing the USB device disconnect or something similar.
I see there's an incompatibility between the Audiolab M-DAC and modern Linux kernels
Audiolab Mdac - years have gone by, still linux support broken | pink fish media
The Audiolab M-ONE has a more modern USB interface, but the workaround for the earlier problem might still work -
connect a USB hub between the Audiolab and Odroid-C1.
IIUC the problem described on pinkfish is with the USB controller, not MDAC. But I may be wrong (as usual).
Mmm, without having read it, my m-one is so to say a M-DAC with a power amp (firmware is up to date, v.1.32, straight from Audiolab-support).
In the past I've tried several "music distributions": Daphile (on an older AMD Zacate), RuneAudio and Volumio. They all ran out of the box, connected via USB.
BTW, Odroid C1+ is connected to an USB 3.0 (900mA) of my NAS because basic power consumption is only 500mA and only RJ45 and the m-one are plugged in. All other constellations before worked fine. No "lags", smooth library scrolling, fast updating and playback scrolling, etc.
Right now I'm struggling with a MPD/mpg123 error. MPD is active but mpg123 reports error messages (something like "socket"..."access"...). Also I can't remove and re-install MPD (failure reports@Debian-Server)...
I'm a little frustrated, it's weekend...and my wife seems to get ill. I think, I have to set priorities for the moment. 😉
Thank you so far!
Thank you so far!
But one last sign of life today. 😉
...call me "Mr.-Clean-Install".
Okay, I'm able to reproduce the situation:
Due to the fact Archphile (not for C1+) based on Archlinux (C1+-ready image available), I'll try the same procedure with this.
Now, I quit for today
- clean install & config
- install mpg123
- comand playback test.mp3 (success by first try)
- noisy sound, dietpi freezes, have to pull the plug
- after reboot mpd autostart failed, no restart in present session --> reboot
- mpd service online
- connect with MPD-app (iOS)
- could press play within the first tracks in library
- it takes a long time...then a flac file comes to the same noisy life
- reboot...
Error messages are there to explain the cause, they are important. They can be copied here from an ssh terminal, e.g., or in many other ways.
- PC Based
- Simple DLNA Renderer for Odroid C1+...or not?
