Okay, I got this:
3.10.107-4-ARC
Linux alarm 3.10.107-4-ARCH #1 SMP PREEMPT Thu Mar 26 05:01:42 UTC 2020 armv7l GNU/Linux
Arch Linux \r (\l)
...and I agree "with your 2 cents" and don't worry about it. 😉
Code:
uname -r
3.10.107-4-ARC
Code:
uname -a
Code:
cat /etc/issue
Arch Linux \r (\l)
Very likely then 🙂
BTW what does the following command say?
Code:
strings /usr/lib/liburing.so | grep -i implemented
OK, your system is pretty barebone.
Or just simple grep should do (don't copy the binary trash here :- ) )
BTW what version is of your liburing? Something like:
Code:
grep -a -i implemented /usr/lib/liburing.so
Code:
ls -l /usr/lib/liburing*
pacman -Q --info liburing
With "grep"...nothing happened.
Code:
Version : 0.7-2
Description : Linux-native io_uring I/O access library
Architecture : armv7h
URL : [url=https://git.kernel.dk/cgit/liburing/]liburing - io_uring library[/url]
Licenses : LGPL2.1 MIT
Groups : None
Provides : liburing.so=1-32
Depends On : glibc
Optional Deps : None
Required By : mpd
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 48.01 KiB
Packager : Arch Linux ARM Build System <builder+xu2@archlinuxarm.org>
Build Date : Wed Sep 23 19:18:00 2020
Install Date : Fri Oct 9 15:26:20 2020
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
As I understand it, you now have ArchLinuxARM running on your Odroid?
As phofman said, I would not worry about the "io_uring" error. I suspect that you have installed a modern version of MPD which supports io_uring, but your ArchLinuxARM has an older kernel which does not support this. MPD should simply fall back to the older method.
Soundirok
So in this case you must configure Soundirok to look for cover art at port 8081, in the "Collection URL" setting.
Soundirok advises to enter this value: http://<local-ip>:8081/music/
but I think the "/music/" part is wrong, because you have configured lighttpd's root directory as "/mnt/music"
so with the appended "/music/" Soundirok will then be looking for the directory "/mnt/music/music/"
I think the correct Collection URL setting in Soundirok should simply be http://<local-ip>:8081
Hopefully this will let Soundirok find your cover art ... but a warning - previously you had Soundirok happily accessing cover art which was being served by nginx, configured by the Rune app.
But you now have a different web server, and as I said before, there are differences in how different MPD clients interact with different cover-art web servers.
OK, I see you have configured lighttpd to use port 8081 - probably because of the Soundirok instructions here -With this I can listen to my music controlled by Soundirok...but no covers.
Soundirok
- PC Based
- Simple DLNA Renderer for Odroid C1+...or not?
