Yup, the broken wires were the problem. A tip to check for you guys, if you have similar problems.
Now the transport is working fine. 🙂
Three pages back. 🙂
Shigaclone MKII Black - The builders Thread - Page 88 - diyAudio
Yep, it's a good one and is the first original version.
While the second SFP-101N-16P is not as robust, I found to perform better.
Regards,
Tibi
Hi Tibi ,
I need the dimension for the LCD front panel and button , can't find in yr website , please help .
plan to purchase a CD chassis from China , want to ask them to cut the hole for LCD panel and hole for the button .
thanks
with regards
What I have is spacing between buttons
11.684mm
460mil
0.46inch
11.684mm
460mil
0.46inch
Hi Tibi ,
thanks
with regards
The best I can give you is a cdr file for Shiga enclosure.
Regards,
Tibi
thanks , I can't open the 2nd file.
Hi ,
I joust bought the same chassis , can share more photo or tip for mounting the sanyo transport ?
thanks
thanks
Hello guys.Here's my version of Shiga MkII Black which I have finished today.
I used this case 田雨音響—CDM3、CDM4 轉盤機箱 that I brought from China where I was on a tour with my orchestra.
The case is spacious and solid with antishock table for cd mech,perfect for the full D-Reflektorized version.
Looks very good and sounds great.
Greetings
I think this has been covered already - but can somebody give me hint or a link how I can get an I2S signal from the Shiga board?
Superb tweak!
Hi guys,
I've had the Shigaclone around for quite a few years now. But for some reason I never tried to tweak it with my favorite cap. So I did now. In both the original Shigaclone and MKII Black.
I substituted C8 with a Jupiter Condenser Red Astron cap. Red “Astron” Style Capacitors | Jupiter Condenser
Sounds marvelous! 😀 Brings a live feel and beautiful reality!
Also, I tried the silver Mica for C11 - I'm afraid I liked the sound better without it. More organic and natural. This just as a remidence that not all tweaks make things better or fit the sound of your system. 😉
Hi guys,
I didn't received any mail notification on your previous post, so I'm happy to see that you solved yourself. 🙂
If you are still unsure what was the problem, check motor cable - 6 wire - from mechanic to main board. Make sure is proper inserted.
Regards,
Tibi
Regards,
Tibi
I'm selling my personal Shiga MKII Shiga MKII ultra high grade
The best digital source I ever heard.
Regards,
Tibi
Regards,
Tibi
Hi Tibi,
Due to a major malfunction on my old laptop that I had a lot of my shiga info on and an incomplete back-up I do not have my shiga black schematic anymore. I was hoping it would be possible to get another copy? I am preparing to to build a permanent enclosure
finally and would like to have as I relocate from board to box just in case. Private no disclosure of course. Thanks!
best regards,
Steve
best regards,
Steve
Hi Tibi, I recently obtained a MkII, and am looking forward to getting going on it. There are references in the threads to 5Vpower requirement for V1 and V2. Can you indicate what is required at these points, and suggest a good approach to providing?
Regards, Ed
Regards, Ed
I personally use Zeno MKII for V1, V2, V3, V4 with separate trafo sections. In case you are interested a GB is open.
Regards,
Tibi
Regards,
Tibi
If you are looking only for a good regulator, all the needed files are in this thread Open source ULN regulator based on LT3042
Regards,
Tibi
Regards,
Tibi
- Digital Source
- Shigaclone MKII Black - The builders Thread
