If I made Colossus again, but I could not get these discontinued Fane FC drivers I used (12" and 15"), then I might pick these:
12"
- PD.123C001 | Precision Devices Loudspeakers (Ughhh that EBP and force/mass)
or
- COLOSSUS 12MB (more like Fane FC including copper shorting)
15"
- PD.153C002 | Precision Devices Loudspeakers
12"
or
15"
I hope that means he's OK and just not participating on the forum.Apparently and unfortunately, Legis is no longer a forum member.
I've been working on a large Synergy style MEH a la the K402 version, but DIY, and had planned to use a pair of AE TD15 below and above like the Colossus, just because I can (I have the drivers already) and wanted to see how it was progressing and if his mind had changed.
Or maybe TD15X x 2, TD10M x 2 and my Unity sort of half Colossus.
How have you made this determination?Apparently and unfortunately, Legis is no longer a forum member.
Hi all, been some time😀 Reason for my absence that I bought my first own house, hifi has been on a semi-pause for quite some time. Colossus' are stored currently, my old Usher D2/D3 with tad drivers back in action.
My future second hifi lair (smaller second house) is in "slight facelift" renovation atm.
Waiting for the times when everything is ready and I can just play oomph all day long🙃
Your first house?! Well done! How do you compare the Usher vs Colossus?Hi all, been some time😀 Reason for my absence that I bought my first own house, hifi has been on a semi-pause for quite some time. Colossus' are stored currently, my old Usher D2/D3 with tad drivers back in action.
Good to see you posting again and congrats on the house!
It's detached I assume?
Yes detached house with two floors. I installed sound isolation double-door between the floors, hifi room is in the basement that is partially under the soil. The separate "guest house" has even greater sound isolation😊
Ushers look so good that I cant put colossus back in anymore😅 The low q sealed setup also does not go deep enough in this big space, with 3-way active would work better.
Old pic with feat. Logans
Congrats Legis for the house , nice area.
I like the brick walls, were the bricks there or did you add them as decorative ? Ziegler sorta carpets are nice, very warm living room
ahaha the Logans seems toys in front of the Ushers, does it sound better in the mid-treble range ?
lol, point of view, for me the Logans just feets nicely the size of the room from an aesthetical ratio... where the Usher are obstructive to my eyes !
I surmise all of us will keep the one that is sounding best, poundered by the waf factor ratio that is different for everyone.... This rooms looks like a dedicated one for the hobbyst only , yeah !
- "Shadow of The Colossus" build thread
