SEWA - Seven Watt Amplifier
Tyimo said:
Hi Lineup!
Mads posted it some "page" before.
No, it is a JFet based RIAA MM pre.
Mad_K said:
I have made countless pcbs for Atlantis. Here's the rev.c layout (2 stereo pcbs):
Mad_K said:
Atlantis Rev.C schematic again:
Thanks, Tyimo for info and Mad_K
for full layout-pcb for Atlantis JFET MM Phono RIAA PreAmplifier
JFET amplifiers schematics are always interesting to look at
😉 Thanks
I put it into my Mad_K folder.
In my Tyimo folder I have several other good schematics.
lineup 😀 even has got a lineup folder with things contributed by him
not very empty folder!
http://lineup.awardspace.com/
Atlantis JFET RIAA phono preamplifier
I have had a closer look at Atlantis RIAA amplifier.
Is it okay to ask questions about it in here
or maybe better I would start a topic in Analogue forum
To explore a bit, this nice and straightforward JFET MM Phono RIAA.
There area couple of things I cant understand how it can really work.
Maybe because I have not designed very much using 2SK170GR JFET.
lineup 😎 will design some RIAA and/or Microphone amplifier project
for his website, later
The preamp. i am planing to use whith Sewa i a tube pre whith Lundahl 1674 trannii build last winter.I is from an artikel on raleighaudio.com
The Atlantis is preamp with a RIAA equalized filter for use with turntables fitted with a moving magnet pickup. You use this between your turntable and the preamp (BOZ) driving your power amplifier (SEWA) 😉
If you don't own a turntable, you don't need it 😉
