whatever ...... preferably BL or V ......... their current is in range of 8-9mA there ; buy 100pcs of J309 (J310) and enjoy
My BL supply dried up building an 8 channel B1 and theres only GRs to find at general suppliers exept fleabay.
You say J309/10 is a substitute?
I would wait for thanks until it works.
He is using LtSpice after all. Has it programmed to whisper sweet nothings in his ear.
naaah
LTS is just handy enhancement of my trademarked Method of Futile Atempts
all my circuits worked , eventually
(besides - this one is so much blatant F1 knock-off , so it is already confirmed)
do me CCS loaded version using R100 and which ever you think is better, schade or no schade. I guess easy enouggh to change either way.
nope prior you finish F6 bal iterations ; I'm not going to increase level of your wakooyankness
that one will need proper servo , if we are not going to make F1 , again
Thoughts of PSU? C-R-C?
Hot parts are M1,2,3 and R13,26,51,27,5 and 32?
3 mosfets and their Rs
you can put those resistors from outs to gnd as 3-watters , too
PSU - whatever please you - nature of amp itself allows not so perfect one ; neg leg is even less critical , having CCS-es as isolation
Oh Yeah. Forgot about that one
Just trying to make sure your not bored
spent freakin hour soldering stupid trs to xlr cable. I HATE soldering cables, but I got Neutrik/Mogami combo for $12 for 2-3' cables whichi would cost almost $80 as finished product. I am beginning to dislike DIY🙂
wasting your time
read The Supercables Cook Book , then try
it will give you few ideas to try , if not recipes
The mogami neglex quad is based on pretty good science and is for professional industry. They dont tend to play games that FooFi do. Are you saying that it is bunk or all cables are bunk? More reading Uug!
I havent googled on what your doing but me and some friends made a shootout on pre to poweramp cables. We had some expensive and some cheap off shelf cables and a bunch of homemaid copper, silver, twisted, 3-braided, 4-braided, coaxial etc. There was easily audiable differences and almost everybody prefered 3-braided solid copper one hot two returns. It was a littlesurprice to me as Im usually no snake oil hugger.
My DIY XLR cables are 3 strands of 22G copper wire in oversized white teflon tubing, nicely braided together and attached to Neutrik gold plated plugs. I only did the mogami thing on my cables for my soundcard test rig. I like my braided setup for listening, for no other reason than it looks good😀 I am sure Ill give the cable thing a go, but so far in future.
You snake oiler😀
You snake oiler😀
there is no snake oil in physics
thin solid cores/foils are way to go , in my sound book
that is not working as EQ , everything else does (at least what I tried )
problem is if you need EQ in your system , and have no other way than oil it with snake oil
to be frank - in cable shootouts , I didn't hear at least half of things guys around me claimed to hear
I always heard other flaws prior to that ....... maybe key is in my approach to hearing things -I'm not searching for details but for amount of involvement
regarding Mogami or not - if you asked for recording or production studio cabling , look no further (I had my mileage spent there ) but for proper hedonistic home system , simply no .
I want my gentle sound firework , when it need to happen , to happen .
One thing that is audible is stability. AC (audio signals) makes the bearer vibratemore or less. Twisting/braiding works pro for that. This also goes for caps btw, its good to nail/glue them properly to something sturdy.
Dang! Spend time chatting with u dodos so I missed my station
Then we are two. Dynamics are everything. One thing Im trying to accomplish in my systems is the dynamic kick-bass. Snare kicks, guitarr-plonks etc. The sounds that hits you in the chest. I care less for deep bass. I usually only get it as I want in headphone systems. I have come halfways with my current speaker filters. I have hopes for this SoZ-offspring here.
Unfortunately I'm oversensitive to distorsion also, I hear it b4 everyone else.
About 2SK170 replacement http://www.diyaudio.com/forums/anal...70-datasheet-says-not-recomm-new-designs.html
- SemiSouth Donuts
