I am now building a PSU with R-Cores from Selectronic... these are quite good sounding devices.
Does anyone have any experience with them ?
These come with primary wires coloured in White and Black.... which colour should I use to connect to live and neutral ?
This is the U.S./North America electrical color code:
White - Neutral
Black - Hot
Check U.S. NEC to confirm. (If you are not convinced)
Note for 240V operation with dual primaries in series connect white of one to black of other.
White - Neutral
Black - Hot
I would expect white for hot, are they not marked at all with this info?
One that I have in hand is marked as: 230V White/Black 15V Violet/Gray 15V Blue/Red. I have it configured as single 30V secondary with Gray & Blue tied together. They usually give 10% more secondary voltage than printed spec when not very heavily loaded on most European wall sockets. Primary side I use White for hot, Black for neutral, and Yellow for mains earth. Yellow is marked as ''Ecran electro-statique'' i.e. Ground electrostatic screen. They are custom made for the French vendor by SHILCHAR India as trained and jigged by the Japanese originally. You can see the SHILCHAR factory logo molded on the plastic bobbin former rings under a light varnish coating layer.
White - Neutral
Black - Hot
i'm aware of the codes, but no, i'm not convinced the EU transformers will follow the US codes, as confirmed by Salas
thanks for the confirmation Salas, i'm buying some of the tiny PCB mount ones from Selectronic for my dac at the moment, but havent got any in hand yet
Then they don't follow anyone's codes then, EU requires EU color codes which are Blue, Brown, and green/yellow stripe.
Black and White conductor color do have specific meanings for North American markets.
What sort of approval do these parts carry? None? 😀
In USA & Canada certainly Black=line, white=neutral. In Europe Brown=line, Blue=Neutral. In UK black used to be neutral, now is blue too. Now, something made with possibly French spec has a White, a Black, and a Yellow primary side. I.e. Go figure. It did not resonate or got hot in my case black or white to line either way.
I think I found their site here: Welcome to Selectronics (Guj) Pvt. Ltd
Since it is an Indian manufacturer that manufactures to customer specification it is hard to know whether any of their component lines have explicit UL/CSA or VDE approvals, that is not to say that OEM end customers do not get the required certifications. I'd be a bit cautious..
This web isn't Selectronic web, Selectronic web is: Résultats de recherche pour : 'r-core'😀
Silchar site http://www.shilchargroup.com/
I had been using black for neutral because it dawned on me, when they are made in India, what is the color code in India? Well, white appeared nowhere in my little google search but black appeared always as neutral both in single and 3 phase systems. Again, go figure bcs the two other colors did not make sense.
Merlin, maybe you have kept their printed catalogue, they used to have some wiring page for R-Core in there, can you look? Maybe they show primary color with a black dot for hot?
I have attached the datasheets for two lines of Silchar R-Core types which clearly state that they are built to comply with CSA and UL standards.
Not sure whether any of the types listed are those discussed here.
Please note also that Silchar is a UL registered firm. I think you can safely assume that the color codes are based on North American convention.
Those that Selectronic sells are single primary but lets settle to Black=Line and White=Neutral when the OEM says UL standard. Yellow is electrostatic screen, that one is explained on their label.
I'd recommend once we get to the bottom of this that the thread be cleaned up to reflect.
Yes, but lets wait a little to see if someone has kept their printed catalog, the one they always pack with goods. That one surely had a guide page of how to use the two secondaries in parallel or series, don't remember if it was showing the primary side with dots too. I just looked, mine is gone too.
- Power Supplies
- Selectronic Rcore Transformers
