Hello Eva, i want to try this. I have a pair of 4530 Single driver horn and the specifications says max loading 50 hz and usable response to 40hz. I would like to add your suggestion of a reflex box tuned lower enough to not disturb the horn. I have never seen one, can you help me with material, dimensions roughly and space from the front of the driver to the wall of the box. Thanks. If anyone can help My email is bvbdan1@yahoo.com
If you can live without the midrange from the scoops, you can just place a closed box of the right size in front of the driver, or even better, you could place a reflex box tuned lower enough to not disturb the horn [ie : below the lowest horn resonance]. This modification will boost sub-bass performance substantially
hello my first time in a chat room ihave been looking at a lot of designs but they dont tell you how to tune them and can you build a mini 21 inch scoop
