Schade Common Gate (SCG) Preamp
@GuidoR I am becoming a fan of the sound of laterals too. I haven't built the more complex higher power amps, but I want to try in the future. Maybe an SCG driving a PP lateral output stage.
With respect to the beefy driver, I started with the SCG buffer, and while it sounded great, it also sounded a bit thin and wimpy, and some loud passages were even screechy. But it showed a lot of promise, and Erno Borbely's articles mention that the laterals need a good amount of drive. So, I tried it with a beefier drive and the thinness was gone, the 'struggle' sound was gone, and it gave way to a glorious, organic sound. Check out the attached article. Erno looks at the slew rate and current drive needed for a 30V swing at 40 kHz and then comes up with 7.5 mA and then gives a rule of thumb of increasing it five times for > 30 mA drive. We're don't have that big a swing with the ElMo, but still I found at least 20 mA drive, perhaps more, is needed for them to sound the best.
The Triad would be fine but its resistance of 50 ohms will mean you will get about 70 mA of current to get the bias point right for the output FET (about 3.4V based on LTSpice for about 2A of output bias). A little more resistance ~70-120 ohms would be better. I am using the Hammond 156M, which puts it in the zone. Please note that I have not finished building this amp yet. Right now, I'm using a beefy buffer on the SCG output and then AC couple that output to the lateral.
Thank you Rahul, a very interesting reading.
Some experiment shall be needed. Member Juma is the master of LATFET, I advise you to refer to many amps he designed.
Re. Triad choke, would it be correct to simply add to L2 a series resistor 20-70 Ohms?
Guido
Reactions: ra7
