a bit more (I think - ?)
38WE/8582T00 – Scan-Speak A/S
https://www.scan-speak.dk/datasheet/pdf/38we-8582t00.pdf
From what I understand it cuts down symmetry induced distortion from waves bouncing around the coil/cone achieving breakup style resonance. Key point is measurably reduced distortion.
I was hoping the 15" unit would be a sub but looks more suitable for use in studio mains.
Great looking drivers but the price is eye watering.
Sorry to burst bubbles, Altec did this years, like decades ago. This low Q 15 is a mid bass pro aplication driver at best. Yes it will play loud, but not in the lower octaves one would expect from a 15" in a hi-fi application. As a hi-fi woofer it is an expensive and near useless driver. Too bad.
I agree. I'd be much more interested in a 15" version of the Revelator woofers and subwoofers.
I have seen distortion measurements of other Elipticor drivers and I was underwhelmed. Furthermore, the Qms is very low. This is bad.
Where did you see a price ?
If it isn't prohibitively expensive it could be used instead of a TAD or a JBL 2216.
Charles
Looks like TD15M competitor to me. Who knows, maybe the next new SS driver will be an oval compression driver? ;-)
Vas is huge, Le is missing.. Simulating this gives not to big boxes, but will need some EQ to get really low. Efficiency is also gone then. It better have very low distortion to compensate.
Vas is not huge it is in the same ballpark as the competitors are. Le is to be found in the datatsheet and is 0.8 mH.
This is not a driver for tiny subs etc, it is intended for real LOUD-speakers and not rumblers, faint-whisperers or loud-screamers.
Charles
Charles
Charles
I found this yesterday. Prohibitive for me 🙂
Solen Electronique Inc. | 38WE/8582T00
Ouch !!! Yes, that would even be prohibitively expensive in real money ! One could save a lot of money by just buying TAD TL1601 instead.
Charles
Charles
What are those then?
Ah, indeed. Missed that one. Could be worse.
But it ain't gonna be that LOUD either.. is it?
Let's put it against the very excellent (budget friendly) BMS 15S430V2, which is around € 300,- each (so you can buy 4.5 of these for a single SS). It can go a whopping 6dB louder from 25Hz up in the same box and same tuning. It's to be seen if distortion wise it does any better.
phase accurate - I hadn't seen the price for the 15" version, I was referring to the elliptical range in general.
vacuphile - The measurements I saw struck me as excellent but the value propposion is so poor it wasn't worth looking any further.
I'll see if I can nab some graphs from hifi-compass later. Does anyone know if hifi compass is happy for images to be borrowed?
No advantage for an oval voice-coil on a 15". These are marketing driven drivers if I've ever seen one. You can get a 24" copper sleeved neo super woofer with 32mm xmax for similar cash. Not to mention the numerous reasonably priced prosound drivers with similar specs.
Who is the primary audience for this line?
- ScanSpeak doubles down with 15" Elipti
