Sansui Alpha AU-907i MOS Limited
Hello to everyone, after few testings there's 2 results for my Sansui Alpha AU-907i MOS Limited problem. 1st the problem is only on the headphones and not on the speakers. 2nd it happens on left channel too. So as I can understand it's not a problem with the amp section and only on the headphones path. The testing was on two options. 1. With power amp direct and 2. With line connected. When it happens I tested all the switches and selectors including speakers switches and nothing changed. Also when the problem occurred the sound on the speakers ok while on the headphones it disappeared. Appreciate your help resolving this . Many thanks.
Which relay related to the headphones? What do you mean about the trans? This is the stepdown transformer that I use. It's 1000W trans.
Temperature difference between channels is usually down to slight differences in bias current settings. Also the physical layout can play a part.
If bias currents are set equal then the dissipation is also assumed equal between the two channels and any difference in temperature in that state is down to physical issues affecting how effectively the heat can radiate.
Reactions: AlphaAudio
