Yes it was, Adele's Easy on me gives me a chill all over.Hello
I would like to hear the loudspeaker. Must be a special experience.
No, it ruins the soundstage.You cut at 300 Hz. The way the speaker looks, I would expect very transparent voice reproduction. Too transparent. I mean to say, do an experiment with a wider baffle. For example a wooden slat 10 cm on one side and 20 cm on the other side. This would make the parts fuller, i.e. more meat on the bone.
Thank you, peril.Sensational work. congratulation
I got a suggestion of improvement.
And that is to vary the distance between the pole pieces, so instead of having 3 mm between every pole piece there could be 2, 3 and mm between in a irregular pattern.
The rationale is that it would make the frequency response curve deviations to have a lower Q. So perhaps no EQ would be required then.
It's very easy to accomplish that should I ever make another SALS?A!.
