Salas SSLV1.3 UltraBiB shunt regulator
Its just a normal 75k 1/4W resistor. Named vrr as it is working with the trimmer. Limits its ultimate value to keep max Vout where we want it to. Because trimmers come in specific values and a little less max resistance was needed.
That Tx will probably give +/- 29V rectified raw DC. Its good for 5V Vin-Vout advised difference across the Ubib assuming you plan to bypass the 7824 & 7924 Pearl 2 onboard chip regulators. It has to be a four wire dual secondaries Tx type, not three wire center tap if that's the case. Because +/- Ubib has independent AC inputs for independent diode bridges in each section.
Reactions: akasaka
Got it. Thank you!
Hi, I have a problem on C1 34.5V out cold 27.5V after 30 mitutes 26.3V, I have J113 560 ohm IDSS 16mA, reserve current 110 mA
From the pdf notes:
You can make it into a fixed output regulator by removing VR1 and replacing with a VRR having that
measured value. A fixed low ppm resistor is more long term reliable than a trimmer and possibly bit
better subjectively. You may also put a Zener in its place with its cathode looking towards R6 in the
positive and towards LED1 in the negative. It would make up for the most of the temperature related
voltage drift but its a rather noisier and harsher choice. If you will use one you should subtract 2Vbe &
2LedVf from its Vz when choosing it for a specific Vout. Use higher value C2 capacitor if for a Zener.
