If you are running less than 4R7 the heatsinks realy start to come into play. Above that the MOSFETs barely get warm anyway.
Some guys have been pushing the Salas reg to silly currents. I tried 100mA, 300mA, 600mA and 1.2A and to me they all sounded the same. I eventually opted for longetivity by keeping everything cool and now run at about 200mA.
100 Ohm buffer resistors Y split to start with.
I'm also looking to do 1 pair R/L of RCA inputs to 2 pairs of R/L of RCA outputs after the PCB1. I'm running my PCB1 as just a buffer having no vol control. I was going to run the RCA in to the DCB1 and then run two pairs of outputs
I'm going to run on output R/L to a tube amp with 180K input impedance and then the other output R/L to a plate amp (28K input impedance) running a sub.
The 100R resistors run on the ouput.. Is this for situations like I have where the two amps i'm driving are so far apart on input impedance?
For the Right channel as an example. Would I run the + output of a R channel to two 100 R resistors and then one resistor to the 1 Right RCA + output and then the next resistor to the other 1 Right RCA + output?
Picture it as simple as this: Put 100R in line with each output RCA. Connect a DCB1 output channel common to the resistors other end.
Pardon my post from a moment ago... Newbie and learning
How hard to run a pair of these:
Just run a set of outputs to these VU meeters?
Meters need dedicated circuits that govern their reading level and deflection speed. You got to research that and/or ask the vendor. 100R goes only to RCA's tip regarding your other question above.
I've done some internet research. I follow you on that needed circut now.
I'm finding some interesting kits. This kit looks like a candidate. This kit is two Analog VU meters and a PCB for the circut you mention. You could power the PCB with the power supply of the DCB1 perhaps. The VU's look a little cheap so I worry about them holding up...
Link to Kit:
VU KIT
For some reason a pair of back lit VU meters has a cool old school look... If I can pull it off and not mess up the sound/performance of the DCB1 then cool. I think I could buy this kit and then just run a R/Neutral/L connection to this PCB and then power this with the DCB1 PCB.
What connection spots on the DBC1 would have DC10-15V? I'm going to run with a 15 100MA tranny
Link to Kit:
VU KIT
Vout, just before the audio circuit has +10, 0 and -10 V. Not sure if you want to plug this there tho, since it might pollute the power feed to the audio circuit.
If that circuit ain't a burden creating too much heat on the 7812 for the relay, take a +12V auxiliary line from there. So not to mess with the audio PSU. Can also tap off from the positive side filter caps with a twisted pair to an additional LM7812 for the meters circuit. With 0.1uF caps across the chip reg's input and output for its stability.
I thought I've seen others running some LED power indicator bulb from the VOUT. The specs on this kit that the DC 10 volt is to just power the LED lights in the VU meters
I supose I could just build and then listen... Try this kit connected and see if I hear any difference?
I'm pretty new to this. I'm not sure what pollute the power feed means.. I was just thinking the 100VA transformer, all the caps in the power supply.. That the power supply would be able to handle just a bit more load.
Just experiment with it. Hook it up on various power feed points described and see if its detrimental at all. If it is we may throw a couple of ideas.
For the "take a +12V auxiliary line from there" How do I ID the spot on the PCB where you are talking about?
Sorry for the noob question here... I am about to place an order with the Canadian toroidal transformer company "SumR". His transformer come with a 117V primary. I understand that Canada has 110V line voltages. My wall voltage ranges from 116-122. I can get him to wind a 120V primary version. Just wondering if this is an issue...? I am planning to get the 80VA, 2X15V toroidal with all shielding. Thanks in advance
120mA with 15VAC trafo and no 7812 sink. Having the relay and the LED to cater for already, say 100mA spare.
The nominal line voltage in Canada is 120V. I am on the same power grid as SumR. I just measured a few sockets in my house and it varied from 118-120.5V. Just take the stock unit.
- Analog Line Level
- Salas hotrodded blue DCB1 build
