Using an old good old HP workstation (Z220) with an asus essence stx pcie soundcard.
Also have a focusrite solo mk3 and a 12bit picoscope at hand, the latter for different kind of measurements.
Switching between REW and Sillasoft Visual Analyzer for software. They do their job for me.
you noticed correctlyDo I see Apogee or Analysis magnetostatic speakers in the mirror finished lid's reflections?
is the Greek epsilon analysis
Yes the Transformers are shielded. used Transformers for Tube Amplifie came out a little over 80VA but I do not mind.DACT is alright. Clean and neutral. The EI transformers have flux bands around their bellies?
I also tried an alps black beauty
But I like the dact more
Looked into it, for IRFP pass elements R3 R4 should be 470R, also add 100R gate stoppers. Vin-Vout should be kept at no less than 5V else drop out will start there due to Vgs is high vs Vbe when normally using a BJT pass. But not >>5V either if used for high current loads because of dissipation & sinking concerns.
- Analog Line Level
- Salas DCG3 preamp (line & headphone)
