Sacred geometry snake oil?
Thus is kinda cool ? (Inside the Giza pyramid)
Yes it is amazing and relevant to many things.
Even including speaker design.
As mentioned you have to be careful.
Just like Humans tend to see " faces" in everything.
Because of pattern recognition.
Often been seen that people
aware of the ratio like to " find" or " see"
it in everything. When it isnt related.
But yes Pyramids have shown height and base measurements
equal to the ratio.
keep in mind
(A+B)/A = A/B
So without decimal points or rounding up
the constant is closer to 2 not 1.618
but overall it still works as far a " pleasing"
or good ratio for objects or design.
When you really stray from the ratio
When you realize how goofy and dumb some things look.
And why it works so well.
Seems nature has done the same.
Often compared to plants. And many follow the ratio.
Also many plants and flowers actually follow
different ratio for maximum sun exposure.
Reactions: Booger weldz
Skinny or wide it works.
Also works well for bracing placement.
And flattest response or least diffraction
falls on the ratio as well
what driver is the wide cabinet for on the far left?
and how many inches.
Been meaning to ask.
* edit* besides the obvious description stating the
name and size LOL
I think we should just consider this sacred geometry to be natural geometry.
sacred ? Do words have sense yet ? The mix of words : natural, sacred, vis à vis of geometry is a pure blah bar theorem. Known here as Snail oil ?
Time to study again the story of geometry and scales numbers since phythagor to Fibonacci instead ? Or pit and gore ?
Look at fractal paterns too, after. Or define again the word "Natural". 🙂
So r u defining ‘snake oil’ as things u don’t understand or don’t believe in? Math is the language of the gods, the universe or your cat depending on yr belief system…a Taoist would say that math u cannot understand represents the Tao…snake oil is made up attributes in order to sell u on something, looking for spirituality in numbers and patterns represents the search for creation and meaning, sacred indeed. No need to belittle others search because it’s not yours
I used to think there was some ‘sacred’ geometry in the location of resonance modes in 1/4 wave . It didn’t really pan out, but there were some interesting numerical patterns in the series of resonances in straight pipes or conical?
(especially if I set the speeed of sound to ‘345.6m/sec, a ‘Pythagoras tuning number for ‘a8 ?)
Some of the messages one can write with the Red ❌ Pen from PWB Electronics are ‘x26‘x and ‘x = PRESENT TIME. I have experimented with Orgone and sacred geometry shapes like tetrahedrons, etc. but never has any luck as far as audio goes. I have experimented a lot with Feng Shui with respect to audio but never had much luck, except in a very general way. But the Red ❌ Pen - now, that was an entirely different story.
Number patterns that aren’t related or ‘math’?
