Russian PIO caps. Should I use them?
McIntosh MC-30’s MC-75’s, Fisher 400 & HH Scott 299c. Good enough for my old ears.
1. Are the last 2 digits of the K73-XX used to indicate the form factor such as radial or axial only?
2. There are various K40 and K42 types of PIO, e.g. K40Y9, K42Y2. Is there any rule of thumb to indicate one is superior to the other?
1. It's only a design number starting from 1. Nothing else.
2. There is not. Some of them are better some are not. You just have to know (to read) about their design or to listen to other 'audiophiles' opinions.
diyAudio Chief Moderator
Joined 2002
It looks to me two legs are the capacitance, the other two are connections to the capacitor's metal case for shielding. Those should be grounded to have an effect. Test with a DMM which ones are which. Capacitance mode and continuity mode should answer.
