Roland JC-120 Jazz Chorus Amp Clone
OK, I see you did reverse them. Try powering the Preamp with two 9V batteries in series to get 18V.
EDIT: " 2SK117GR via Aliexpress" - may be issue, I have a pile of fake 2SK117 / 2SK170 from ebay...there is one guy on the bay that does sell legit 2SK170...but before replacing them, try the battery...
The pre has a lot of gain too.
You can take a resistor at the pre input across the Signal to ground (right at the jack). Start out with 470k and raise closer to 47k and it should quiet down and lose a little gain - pick one that sounds best...
Also, see original schematic. With Hi input has 33k in series, but with low input, 33k in series with 68k to ground for voltage divider to drop signal level. You may want to play with a resistor to ground there. I just put a resistor to ground right at jack and worked fine.
Also, my fake 2SK-117 worked, but did not sound as good with real 2SK-117 / 2SK-170
Right on! I’ll keep fiddling around. Replaced the preamp of a Peavey Backstage 30 with this preamp and it sounds great. Fortunately, the preamp section of the Backstage pre takes ~30vdc which made it easy to steal power.
hi! are there any pcbs left? I´d like to buy one, also, where did you guys get the dale rn55 resistors? I found a seller on ebay, but just sells some of the values required, not all of them, is there any hearable difference if I use regular film resistors? thanks!
