Rockford Fosgate T2500-1bd
Rectifiers are installed amp is at 5 amps of current draw at idle
Here is what I get on the bank of fets I can see the waveform change slightly with the whining of the transformer .
Scope set to 10us 10volts/Div
Here what I get after adjusting the trigger level
The amp will produce clean audio .
The transformers have glue all over them from the factory . Is there anyway to quiet the hissing / screeching ? I can move the windings or twist the transformers since they are glued
