Rockford Fosgate T2500-1bd
Are the ones marked W1G a06’s?
How do I determine what’s wrong in that bank ?
The outputs heat up like crazy if I add all 4 outputs in that bank it blows them instantly.
If I only have 2 outputs in that bank they heat up but amp will play clean audio.
All the diodes and transistors resistors check fine
I double checked all of the resistors all check good .
All of the didoes and transistors check good as well and I checked for open junctions all seem fine .
If I measure voltages on the transistors o get different readings from around 1 transformer to around the other transformer.
For example all of the 2g’s have 19 volts on all 3 pins besides one and that on I only get 9 volts
The outputs can't heat up without rail voltage.
You may also need to install a jumper on the driver board.
After desoldering the rectifiers, post a photo of the drive signal on the heating FETs.
Confirm that the rail voltage is 0v and you can connect your scope's ground clip to the source leg of the FET if you can't get a good signal.
If you need more pics let me know .
