Rockford Fosgate Power 360a2
R215 has 16 vdc on one end -1.628 vdc on the other side.I checked it for ohms and it had a really wierd reading like 1.567 ohms in circuit so I removed it from circuit and it tested at 55 ohms which is way out of tolerance. I will change it and post my result.
Yes they look the same as the input signal just U201 does not have the amplitude in signal that U202 and U203 do. Shall I check to see if the signal is going to the cross over selector and not back out. Switching the switch to all positions makes no difference.
I installed a bananna clip onto my ground (like you told me to do along time ago) and got a different result. The signal looks the same on both sides of C223 and C111 just like the input. The pin 7 on U201 U202 U203 are the same as the input signal, just a little less on the amplitude of U201. I checked the cross over selector switch and have the same signal as the input on all pins.
