Rockford Fosgate 100x2
Hi, i have this old 1996 fosgate 100x2 amp This amp was working good when I stored it away and now only one channel works. I tested the speaker output and got 32.4v on the right channel? I check alll the output transistor and the 1 ohm resistor on both side. They check out okay. The left channel is fine and plays music fine. Nothing was burn. What am i missing here. I would like to say thanks to those of you that help me before. Thanks to Perry for all the help and time. I know he's busy i appreciate Perry your time.
If you're absolutely sure that none of the output transistors is shorted, give me the DC voltage on each FET in the defective channel with the amp powered up (no audio). Place the black probe in leg 3 of the FET being tested and the red probe on leg 1 and then leg 2. For each transistor, post the circuit board designation.
Q#
Leg 1:
Leg 2:
Q#
Leg 1:
Leg 2:
Q#
Leg 1:
Leg 2:
Q#
Leg 1:
Leg 2:
If you have 65v from gate to source on the top 2 FETs, they're VERY likely defective but I see no way to get that voltage. Confirm that you had the probes as shown in the attached drawing.
Try it again but this time, place the black probe on chassis ground.
Q225
Leg 1:
Leg 2:
Leg 3:
Q215
Leg1:
Leg 2:
Leg 3:
Q219
Leg1:
Leg 2:
Leg 3:
Q224
Leg1:
Leg 2:
Leg 3:
Are there any burned SMD resistors near the bias pot? The ones marked 200 are the ones you need to check. Are they within tolerance?
Sorry i had them in the wrong place, but i have them like it would be on the amp.
Q225
Leg 3: -32.29
Leg 2: 32.47
Leg 1: -32.7v
Q215
Leg 3: -32.29v
Leg 2: 32.47v
Leg 1: -32.7v
Q219
Leg 3: 32.47v
Leg 2: 32.47v
Leg 1: 14.79v
Q224
Leg 3: 32.47v
Leg 2: 32.47v
Leg 1: 14.79 v
