Yes, the drivers and predrivers are soldered in (in a line ready for tapping into a heatsink) but they are unpowered.
It is easy to connect the NFB pad to C1 since both are above board, whereas the collectors of Q15 & Q16 + extra resistors would be below board.
I'm away to remove the FC resistors and move the NFB tapping point.
Andrew, please measure the voltage drop over R12, R13, R14.
Also, measure the voltage drop over R15, R18
changed R15 & R18.
1227 & 1225mV across indicating ~8.3mA.
The mirror has reduced current to ~1.6mA, leaving the same ~6.7mA flowing into the cascode. As expected the R19 current has not changed.
Vr12=1.3mV
Vr13=0.3mV
Vr14=0.2mV
These seem to confirm that the transistor have sensible hFE.
Not moved the NFB to the Q15 & Q16 collectors yet.
Total current draw down to ~19.5mA
Vr12=1.3mV
Vr13=0.3mV
Vr14=0.2mV
not if it's showing 420mV of drop.roender said:D1 is correctly mounted?
Maybe is reversed ...
Andrew,
If every CCS is working properly, then Kirchhoff is the guy responsible for proper RMI-FC100 operation 😉
Right now, I have no idea what is going one ...
Sorry
Mihai
Sorry
Mihai
It's running off my lab supply set to maximum of +-31.6Vdc.
Not far below +-39Vdc specified for the front end.
What would the symptoms be, if either the Cascode transistor/s or the input jFet/s were damaged?
I've been poring over the schematic for days to try to find the missing current. Checked the resistor values for R20=1k2 and R29=9k96
Andrew, you could measure all BJT transistors mounted on PCB.
There is a small possibility to find some PCB vias without metal deposit. Take a closer look around 10K bias resistor
Lift Q17 collector and insert 1k resistor. Measure the voltage drop and calculate the current through resistor. If you find something very different than 1mA then Q17 is damaged ... otherwise something is wrong with Q21 or/and Q18 or j-fet transistors
I fitted the 470r resistors last night and moved the NFB to the connection. No change.
I will measure Vbe and Vce of all the transistors.
I shall double check the current in the collector leg of Q17. It's unmatched and easy to replace if I overheat it.
I'm loathe to take out the cascodes and jFETs on a hunch, until I'm sure one or other are at fault.
replaced Q17, no change.
shorted D1, now 850mV across the 9k96.
Vds of the jFETs is +5.6mV.
Vsg = +717mV
Vdg = +722mV
It appears that the Vbe of the cascode and the Vds of the Fets is setting the voltage drop across D1+R
Cascode sits with Vce=2.4V, Vbe ~700mV.
Looks like my next step is pull out the FETs.
FETs out and Idss are still matched.
Where to now?
Vsg = +717mV
Vdg = +722mV
Where to now?
I think that's exact. And it is the reason i think D1 is leaking. My first step would be to change this diode with a eally good one, mean no measured leakage in this order on the bench.
I will do measurments in mine when i will have time.
Did you measure the Idss for k170 used? What values did you found?
I will suggest you to measure all components ... also, please verify all the links between components to be in conformity with schematic. It is hard work, but it is the only method which can give results is short time.
If everything turn to be just fine, then jfets are toasted.
On the datasheet of 1n4148 the curves shows about .45forward voltage at .1mA. So when connected in parrallele with a Vbe of about .65V (Q18,Q21) it's normal that the diode conduct a little, and your numbers seems to be normal for me.
If this diode have forward leak above this the problem may be amplified. So i think this is normal that a small amout of current 'leak' a bit by D1, even if the Jfets have a 0V VDS.
Denis
Denis
- RMI-FC100, a single stage audio power amplifier
