Retro Amp 50W Single Supply
Yes my friend, let's wait someone to help with the simulation, then i know a good friend ho can do the rest. :up:
Your good friend has asked me to deliver this to you😉😀. It just something I made in 6 hrs straight.
regards
Prasi
Wow Prasi, you’re a machine. Very generous with your time.
thanks man!
2N5551 for T2 ... I'm not sure. I would put a BD139 there (and a small heatsink).
Ok, Not a major problem. done...Small heatsink can even be a 1-1.5 mm al plate bent in u-shape. may be BF469/471 are better placed for T2 duty?
regards
prasi
Hard to tell - these BF469 are 100mA parts. Perhaps a BF457/458? But these have lower hfe (!) Would have to measure each before install. A BD139 seems like a "universal fit", ha ha.
But yes, the small U-shape h-sink is what I had in mind when suggesting that.
A sidenote - with TO126 vas (probably useful if someone wants to build a "macho" version running on higher PSU rails), a TO92 BC639 would be pin-compatible (also bce) if somebody wants to build a scaled-down version...
