Resistor Sound Quality?
DC applied through what another resistor and the battery. Directionality aside there is no, known to me, data that shows lumpy noise spectra from any resistor. I have been reading noise literature for 40yr.
Keeping with the theme, would a Makita battery be the right tool for the job?
Probably. The resistor is connected directly to the battery. Next run will include additional resistors. This is just playing to see if there is anything interesting to really look at. No claims other than it is interesting and worth some investigation.
It differs from the typical stereophonic setup with two channels as the sound sources are positioned at angles of 30 degree (ref.to the median plane).
As said above it depends on the frequency range, a pure low frequency sinus will most likely be per percepted at "dead center position".
The HRTF allows to extract directional information even in monoaural listening (one ear nearly deaf) if the frequency content is sufficient.
But the subgroup i´ve described seems to be unable to percept the phantom sound source (or virtual sound source)
Ok. Do you have any hint where I can find a paper on this? Do you remember if members of the subgroup are able to tell the position of a real life soundsource?
Jeez, I've just spent $150 on ten 0.1% Vishay Z foil resistors for the RIAA of my phonostage, way to take the edge off the purchase you buzzkillers.
That said, I don't actually expect it to sound any different than with the 1% DALE RC60, but you've got to try these things once to dissuade yourself of these silly notions.
I would like to show what 'prime predators' like me, were looking at 30 years ago. Listening tests, even double blind, were implemented on occasion, even then. We cared then, and we care now. We find that open listening is the best available option for hearing subtle differences, even in the face of strong criticism as is shown on this thread. Take a look at the level we were researching 30 years ago. You might be surprised. And a few questions might be answered that are not yet here.
Maybe I have something wrong. My understanding of things was that a soundwave travels to both ears
and depending on the time difference that wave hits the left and the right ear sensing of direction is possible.
There's more to it than that. The frequency balance is shifted when a sound arrives at various angles,
due to the outer ear structure and shadowing by the head.
A single sound source will thus present a different frequency balance to each ear when off center horizontally.
