Resistor Sound Quality?
What a curiosity, this untrustable brain. Apparently, it's honest with us with the music we love, letting us enjoy the sweet tone in a particular singers voice or allowing us to hear accurately a particular guitar riff. But with audio equipment, our brain transforms into an unremorseful and malicious liar, refusing to let us make heads or tails of what we're actually hearing, or even worse, taking a demented pleasure in making every single piece of gear ever made sound EXACTLY the same !! Oh vile and cursed brain !!!!!....why do you toy with us in this manner ??!
Suggest some reading on perception and how music effects us and our ability to recognise and be affected by rhythm, Your answer reeks of a GEB Audiophile who's hearing (unlike the rest of us mortals) is infallible....🙂
No is only a stupid provocation
No it isn't a stupid provocation (unlike some of your posts I could have said but didn't), understanding current flow is critical if you are going to design a layout to achieve the best fidelity in a circuit... claiming directivity with ac signals is a bit silly, as is claims of electrons being lined up or their paths smoothed out by esoteric components... You have to think in terms of EM waves not electrons because electrons just jiggle about at a leisurely 0.1mm/sec (or their about), so again, what is the current loop direction when an AC signal is present...
The only way that distortion can remove harmonics is if the distortion is the inverse of whatever added the harmonics. This is difficult to do deliberately, and almost impossible to do accidentally. Statistics tells us that there is one way to do it right, and lots of ways to do it wrong.
Therefore, if anyone prefers sound with added distortion this simply means that he prefers distortion - not that he is removing existing distortions. If more 'audiophiles' would admit this simple fact then many arguments on here would vanish. I have only seen a few people who do admit this of themselves.
Well in reality maybe, but this is audio and we have things such as the Bybee QP THAT can remove noise whilst leaving the signal unaltered😀...
C'mon, you very well know how that "effect" is generated and I am not sure if any human with organs in working order (!) is able to switch off detection of time delay differences or lack thereof that create that effect of stereo. And why would anyone want to?
Afair there is a small percentage (i have to look it up again but it think <2-3%) of humans who do not percept a "phantom sound source" in the median plane if two loudspeakers in front radiate an identical signal.
So, this subgroup´s perception is much more accurate (from a technical/engineering point of view) but these people can´t benefit from stereo reproduction
In a broader sense it is quite funny to describe the reproduction of sound as a pure engineering effort as engineering can´t tell anything about the percepted quality of an imperfect reproduction.
What is it if it isn't engineering..... It involves analogue and digital engineering, acoustic engineering, mechanical engineering, measurements and listening are all part of this process!
Marce,
You might just want to build a simple discriminator circuit for the AC mains.
All it requires is a simple center tapped transformer, tap common, a pair of diodes from the end of each winding charging matched capacitors with high value discharge resistors across them. If both diodes charge to positive, you should not be able to measure any voltage between them. However you will find there is one.
Flipping the AC mains will flip the difference. This is called DC on your AC. It is caused by asymmetric loads on the power line. This has the effect of moving the zero point in power transformers BH loops. A small decrease in efficiency results.
What actually may be happening in the clipping audio power amplifier may be a shift in the power transformers conversion efficiency. The test would be to precisely measure the rails voltage under no load before and after the clipping episode.
Maybe I have something wrong. My understanding of things was that a soundwave travels to both ears and depending on the time difference that wave hits the left and the right ear sensing of direction is possible. Zero time difference -> zero difference of angle between ear and source (English is not my first language, I hope you are still able to follow) -> source is dead center.
When there is a sound displayed from two speakers that project the same waveform and the run time difference from the left speaker to the left ear and the right speaker to the right ear is zero, then to me an accurate perception is for that sound to not emerge from the speakers but from the center between the speakers.
Yes, the spacing of ears is not enough to have accurate placement by time of arrival alone. Think phased array theory. The HRTF is required to actually position things. So at least two effects in place to locate things (and how we can tell if something is in front or behind of us with 2 ears). That it works at all is amazing, that it goes wrong now and again is not suprising.
NO NO NO. All a filter can do is reduce the level of harmonics. It cannot reduce them.
And if you reduce them way under the noise floor? Aren't they effectively removed? 😉
And BTW I've told originally of an apparent more or less harmonic content, not necessarily eliminated but possibly increased or decreased in level.
Clearly audible is the sound of a ripped woofer. I think you mean 'consistently detectable'.
Fine, it falls under English nuances I may be missing. Thanks for the suggestion, I'll try to use it 🙂
Fine but still can't see how this possibly contradicts what I'm stating... Maybe I could define it better: distortion can both increase or decrease level of harmonics.
