Reflektor-D builds
The sinks aren't pre-grounded to save insulation hassle and enhance heat transfer. Its better to have option than not. Normally it isn't a problem. Try to see if influential in your case. Nice to know you like the sonic results.
You may tune up Vout by taking advantage of the Rx/J/D position. Say by leaving in the LEDs you now got and add some Rx value. Or replace them with lower Vf LEDs and add a diode. Whatever suits you. Don't do such experiments with the real load connected. Use a dummy load, tune your Vref section parts for target Vout well and steady, reconnect when sure. Not to kill chips with some overvoltage set up mistake.
On the Rx pads female socket pins can be installed to easily try various resistors. To go from your 5V base up. If for 2mA nominal current in the Vref expect 0.2V additional Vout per 100Ω. If using the JFET mod probably more mA will be produced and more mV/Ω.
Yes, you could use a trimmer instead to home in. Must be arranged as a rheostat though (one of its outside pins joined to the middle pin). Plus its not easy to connect it and use it there due to its shape and pins arrangement. Maybe with small wires. Still better to be replaced with a standard resistor of near value after removing the trimmer and measuring its set value.
Its about replacing the R6 resistor with a JFET as an active current source. Gives an alternative technical and subjective character to the reg. Yes there is information, characteristic posts with pictures are #149-156.
Here are some pics. Not exactly great soldering as Mundorf Silver Gold solder leaves a lot of residue which is difficult to clean.
