Reflektor-D builds
Almost ready.
Yes, look at their datasheets there. There are forward current vs forward voltage curves. If its the 1k R6 resistor style REF-D you use, there are 2mA running in the Vref. If its a JFET mod then its almost IDSS of the individual 2SK. Maybe 20% less because the voltage threshold isn't the 10V IDSS test level across the FET but only near 2V. You want at that current in the LED curves, the colored LED VF + the IR LED VF + 1.22V residual from the mirror transistors Vbe to give 4V total.
You will have to calculate. If its a build with R6 1k then the Vref current is about 2mA. In that example 120 Ohm would bring 2mA*120 Ohm = 0.24V. If its JFET mod and you aren't sure about the exact Vref current, the 10 Ohm will develop a drop that will show the way. If it is 0.4V then 4mA is running. So 62 Ohm would bring 0.248V extra.
