Reflektor-D builds
In oscillation issues everything plays a role and its usually bad luck finding the exact resonance. Output caps, input ditto, cable length etc. A one ohm resistor can stop it. If it isnt internal oscillation in the BIII. The SSLV is pretty well protected.
You can go down to 0.75R R1 (1.5//1.5) on the REF-D but I propose not to push it more. Since those switches combination managed to make a bench PSU smoke and blow a fuse it is not something we can further try solve from our side.
Recently completed Reflektor-D (.7A CCS @ 5.25V). Running well into the 60's with the stock cover on, so I did this... About 10C cooler now. This is on my Buffalo 2 dac, ~555mA load.
