Reflektor-D builds
The model 55? It scrolls and mentions current if I remember correctly. Maybe 5mA.
At 2mA those reds were 1.735V. You got to test with dummy on the reg, wait to go hot and measure. Just solder lightly on top edge of the pad before finalizing choices. You don't have to use diode only, you can use resistor also. 0.02V for 10 Ohm, 0.2V for 100 Ohm etc.
Reactions: tamra
Still more than in the reg. Look in the instructions there is a diagram with a resistor and a 9V battery for 2mA. Maybe two greens and a small resistor instead of diode will be the easiest in the end. Has to be 5.25V exactly, or there is allowance?
With battery one green LED 1.904V the other green LED 1.903V
If calculations are OK: 2 green LEDs + 100 Ohms, OK?
Seems OK. Although it will go a bit down when hot depending on how hot. Don't solder LEDS & resistor through hole, just lightly on the pads edge to can exchange the resistor mainly. Monitor straight power on cold Vout also not to cross your application's max dangerous voltage zone.
